QUOTE(Jeffs9146 @ Jan 20 2009, 10:18 AM)
This is what 30 hours of sanding and polishing will get you. After I figured out how to get the job done, I figure I could do this in 8-12 hours. This wheel truly was like a mirror. Zero scratches. If you looked at the sun's reflection in it it would blind you.
I remember those! Are those the rims I sold you 6 or 7 years ago? Do they still look that good? How are they holding up? did you do a clear coat or anything to protect them?
You know, I think that wheel is one of the ones I bought from you back in... 2000, 2001? I only did the one wheel. Like I said, this work taught me the value of Al Reed's work. He and Diane have done all of my wheels since. I bought my first 914 back from the guy I sold it too and it included that wheel. It's dingy, but I'm confident that the wheel will polish right back up again. I have an "after" picture of it on the site somewhere.
QUOTE(Cevan @ Jan 20 2009, 10:46 AM)
QUOTE(Gint @ Jan 19 2009, 07:01 PM)
Hey Gint, that is perfection. What did you use after 2000 grit?
Regular metal polishing compounds. I don't remember exactly what I used, I'd have to go out and look in the box of supplies (after I found it that is). I did that years ago. I did use a bench grinder with a polishing wheel as well as a flex shaft off of a small delta bench mount belt sander. More torque than a die grinder. Worked pretty well.
