QUOTE(Eric_Shea @ Jan 26 2009, 08:37 AM)
This is where it gets weird; the 914-6 CV, while the same size as a 914 CV has a different spline count from the 914 CV. Hence, microscopically different CV and different axles.
This isn't an issue though if you're just looking to go 5-lug on a /4, right? Since you'll be mating to 914/4 CVs?
914/4 axle--->914/4 CV--->914/6 stub axles--->911 hubs
I think the 914/6 axle issue comes into play when you start talking about beefing up the engine where the /4 axles (and possibly CVs?) aren't up to the task.
QUOTE(r_towle @ Jan 26 2009, 08:56 AM)
So to get around this could one use a 911 stub with 911 CV joints?
Yep Rich, but finding the right axle is where it gets tricky, from what I understand "no" 911 axles will work because they're the wrong length. I'm pretty sure that Eric has worked out a solution utilizing Sway-a-way axles and a little chicanery to go along with them though....Mr. Shea? Andy worked on an approach with 944 parts too (I'm sure you've seen that one).
Reid
