QUOTE(SirAndy @ Jan 23 2009, 03:41 PM)
WEVO can do it but Hayden ain't cheap.
Andy
I plan on using their tail shifter set up but hoping not to sink a fortune in the trans.
QUOTE(stevesc_us @ Jan 23 2009, 04:00 PM)
Hollerans in Pinole does excellent work. Knows 914-6's inside and out. He has done alot of work on my original six and I won't trust my car to anyone else. John does complete engine and tranny rebuilds and is a master at body work. You should stop by and see his shop and take a look at the six GT conversion he is doing for himself.
Glad to hear. If I dont hear of any other compare/contrast I will probably use them. John from Valhalla giving them the thumbs up was good and having 2 people say their work is good seems like they would be worth a shot.
QUOTE(GeorgeRud @ Jan 23 2009, 04:15 PM)
This may be a silly question, but does the pinion depth have to be changed if you flip the 915? It seems that you're not changing the pinion depth by flipping the differential if you keep track of the thickness of the gaskets as it came apart.
It certainly does make it more of a pain to set with the flip, but it is important to have a quiet transaxle. If those gears were happy with each other before, you don't want to mess with their marriage!
To tell you the truth I have no idea. I have never taken a transaxle apart. I was just picturing a differential and how they are shimmed. I was thinking left to right might not 100% equate to how it would be shimmed right to left.
Does the ring and pinions assembly come out as a unint and just have to be litteraly moved to the other side?
