AZ914
Feb 19 2004, 12:48 PM
Hey!
I'm looking for recommendations on securing the aluminum windshield trim after it was removed for my paint job. I thought it was down tight but at speed, it starts lifting off the car up on the roof line.
Any suggestions on the best way to secure the trim? silicone, etc..
Thanks
davep
Feb 19 2004, 01:28 PM
Did they replace the clips that hold it in place? Did they get the glass recessed to the proper location? If both are not done correctly, the trim will not stay in place.
DaveP
scotty
Feb 19 2004, 01:55 PM
...the top center cap is the first to go
As a kludge you could use some clear silicone sealer...
campbellcj
Feb 19 2004, 03:40 PM
I had that happen once on my previous 914...I had the top off and managed to catch the trim piece as it was about to launch up over the car and onto I405!
The plastic clips usually hold it OK when it good condition. I'd check that first.
You can also screw the trim down, or use the racing windshield hold-down tabs (which will also hold down the trim)...if you don't mind the non-stock appearance and punching holes in your car
I have some of the pretty (and expensive) little alloy tabs from Smart Racing Products to install shortly.
AZ914
Feb 19 2004, 04:13 PM
Thanks.... its probably the clips. I didn't have the windshield out for the paint job, just pulled the trim and masked the glass/rubber. I think I've seen those on PP -- I probably have some broken ones...
It really sucked driving with my hand out the window holding the trim down...
Brad Roberts
Feb 19 2004, 04:17 PM
They are one time use only. Pull chrome off for anything.. better plan on replacing them.
B
markb
Feb 19 2004, 04:49 PM
QUOTE(Brad Roberts @ Feb 19 2004, 02:17 PM)
B
Don't you also have to pull the windshield to replace them?
campbellcj
Feb 19 2004, 10:22 PM
I'm pretty sure you do have to R&R the windshield and seal as the clips are kind of embedded in/under the seal...
meursault
Feb 19 2004, 11:08 PM
The hell with it. Use duct tape, but only the type that is rated for 200 mph.
Seriously, though, you need to remove the windshield to replace the clips. Any time a windshield is replaced, the clips should be replaced at that time as well. You'll hate yourself later if you try to use silicon to keep the trim on.
scotty
Feb 19 2004, 11:48 PM
BIG time!
d7n7master
Feb 20 2004, 12:30 PM
I removed my windshield trim for paint too. I had a bitch of a time gettin' it back on. Ended up using black RTV. The trim bent in places it wasn't suppose to bend when I was re-installing it so not it looks worse than before I removed it. I don't like it but new trim is big $$$. Doesn't anybody make "cal rubber" for 914's? It looked good on my bug.
krk
Feb 20 2004, 12:39 PM
QUOTE(campbellcj @ Feb 19 2004, 08:22 PM)
Well that sucks. I'll have the same problem with mine once it runs. The trim on the lower drivers side seems loose at the corner.
kim.
