jsayre914
Jan 26 2009, 02:11 PM
I am curious for those who are using a fuel pressure and oil pressure guage, did you drill a hole in the firewall somewhere. How do you get the wires from the bay upfront to the guage? Is there a correct way?
PeeGreen 914
Jan 26 2009, 02:15 PM
I just ran mine alone the wiring harness. Wasn't too hard.
RickS
Jan 26 2009, 11:54 PM
I don't know how correct it was, but I took mine up the center tunnel from the engine compartment. If I remember correctly, there is a rubber grommet or plug I took them through, then up the tunnel and into the back of the gauges. You may want to try Phonenix's method because I found my way a PITA.
McMark
Jan 27 2009, 12:00 AM
If you're crafty, you can get them shoved through the stock wiring conduits.
70Sixter
Jan 31 2009, 01:10 PM
If memory serves, and mine often does not - check for unused wires under dash and in engine compartment. Wiring for A/C or some unused option.
My first -6 had one or two. Seems like green & black. I used one for oil pressure gauge in ashtray opening.
