Txgasser
Jan 27 2009, 08:06 AM
Can you use a Type 1-009 dist. on a 914-4? Johnny!
So.Cal.914
Jan 27 2009, 08:09 AM
Will it run? Short answer-Yes.
Borderline
Jan 27 2009, 10:39 AM
Not if you're running stock FI. It will run if you have carbs, but you may want to adjust the advance mechanism.
Shade Tree
Jan 27 2009, 11:02 AM
I recently bought a '74 with dellortos and an 009 dizzy. A stock dizzy from a fuel injected engine ran much better even without the vacuum hooked up! The 009 just wouldn't advance far enough. I have read recently that they are now making 009's with 28 degrees of advance. I think it was the the Made in USA Pertronix version. It comes with a flame thrower ignition module too.
