QUOTE(ahdoman @ Jan 29 2009, 06:55 PM)
I'm trying to get the electrical straightened out in my 70' project. I have full lights, no flashers and no blinkers. I've checked and double checked all connections and everything is right. I know the bulbs are good. If the key is not on, and I move the indicator left or right the indicator light comes on (not blinking, just solid) in the lenses. I have also replaced the flasher relay with a good known relay. Any ideas? I also don't have dash lights yet. That's the next trial.
That's normal with the switch off, see if your 4 way flashers work with the key off
this will tell you if the flasher is good, if they don't work check for power on fuse #11 both sides while your at it, check fuse #7 (dash light power) with the key on.
Let us know the results.
