Are you using jb weld to hold the races on a slightly worn spindle or to seal them instead of using the o-ring?
Niether.
I'm using them to install the races on a very good spindle vs. using the shim stock. If you plan on refinishing the arm this is the best way IMO.
It's hard to explain without the arm in front of us to demonstrate. The arm needs to be cleaned of paint and/or powder in most cases. The race is shorter than the section of arm it will fit over. This will leave that left-over section (exposed section once the race is installed) bare metal.
I find it best to take a clean arm and JB Weld the race in place then have the powder coater carefully tape off the race. This way you will have complete coverage on the arm and no exposed bare metal areas.
I'm using this method on Bob's arms with the Elephants and my arms with the FreeMotion races. No issues with the shim stock, I just like the JB Weld better.
Bottom line: If I powder coated the arms prior to installing the races I would have to take a good deal of powder off leaving a section of the shaft bare. By installing the races first then powder coating, this issue is resolved.
