QUOTE(biosurfer1 @ Feb 9 2009, 10:46 PM)
Hm... you've got me looking for room in my garage for one of those units. FYI, if anyone is looking at one of these units, if you sign up for HF's email alerts, they have extra coupons and often give you a 20% off any single item, which would work great for this item.
Gint, what do you have to do to the cabinet to make it work well??
Answered that in post #10
QUOTE(Gint @ Feb 9 2009, 08:40 PM)
QUOTE(biosurfer1 @ Feb 9 2009, 08:36 PM)
got any pics of your blasting setup?
H.F $300 unit. When I bought it years ago it was only $180. Works fine after a few mods. Right after I purchased it and got it built I added a permanently mounted whip hose and had to "work" the door at the bottom of the hopper so it would seal worth a damn.
To be more specific, the unit had a hole in the front for the air hose to go through and a barb fitting for the hose to attach to the gun. Pretty cheesy. I made up a permanent fitting for the front of cabinet with the help of some hardware from the local ACE. Attached an 18" (I think that's the length, also available at H.F.) swivel whip hose on the inside of the cabinet and a real fitting for the gun.
The trap door at the bottom of the funnel for removing media leaked like a 914, so it had to be re-worked a little to be more accommodating. How I did that would take more time to explain than it's worth. You're sharp enough to figure out how to get that to work if you buy one.
I'll get a few pics after work and post later tonight if you're really interested.
