BGman
Feb 20 2004, 11:35 PM
POR warns that their product is not UV resistant and will discolor in the sun. Discolor? Is that all, or does it break down? I am considering finishing my engine bay right now with it. Is this area protected enough...or is it going to need to be topcoated. Car is garaged when not in use, and I don't use a raintray (which I suppose would help in this case). Thanks.
-g
Evill Ed
Feb 21 2004, 07:05 AM
Yes, with the POR, it is mostly an asthetic issue. The resin appears to be safe, just the pigment fades.
The engine bay should have plentyl of protection from the direct sun and UV rays.
Ed
7391420
Feb 21 2004, 08:14 AM
I used por 15 three years ago to re-paint my oil filler pipe on the back of my house.
-I'ts survived 2 summers out here without any noticable change
aufaber
Feb 21 2004, 02:16 PM
If you use black.. nothing realy. if you use silver it turns kinda greenish yellow.
BGman
Feb 21 2004, 05:34 PM
Thanks guys- just what I wanted to know. If you have used it outside and have seen little/any change then I am comfortable with it.
I really like the stuff, but boy do they have quite a system-
1. degreaser
2. metal prep
3. por
4. cover paint, or
5. "tie-coat" primer for aftermarket paint and then the aftermarket paint itself !!!
ingenious.
dmenche914
Feb 21 2004, 06:43 PM
Used POR silver paint to touch up my silver car exterior, in a few months it turned greenish silver, YUK. also used in engine bay, out of the sun, and no real change noticed after about a year.
good stuff, but top coat it if exposed to sun.
dave
