RustyWa
Mar 29 2003, 11:54 AM
I just pulled my distributer out and I'm not sure if I have a sealing ring installed. I was expecting to have like an o-ring at the top of the distributer shaft to keep the crud out.
There is a black band about half-way down the shaft...is this the sealing ring? It doesn't seem to be very soft and pliable.
Mark Henry
Mar 29 2003, 12:37 PM
Yep that's it!
Sounds like it's real old, should be soft. The old beetle ones are the same part. Replace it.
RustyWa
Mar 29 2003, 06:07 PM
Got the new one in. Man it was very tight! The old one was pretty much non-existent. I would line the distributer shaft up with the hole and it would pretty much fall to the bottom.
Thanks.
Found a VW only shop near my work today while I was looking for the seal. Oval's Motorsports in Federal Way.
anthony
Mar 29 2003, 06:27 PM
I had a new o-ring and couldn't get my distributor installed with it. My old was o-ring was more of a flat band. Was that because it was so worn?
RustyWa
Mar 29 2003, 06:31 PM
My old one was totally flat. Felt more like plastic. The new one took a lot of greasing up with motor oil and pushing/twisting to get it to POP into the bore.
Bleyseng
Mar 29 2003, 06:34 PM
They should have a flat side to them, they are not a typical O-ring. When new they still are alittle tough to get to slide down in the bore.
Geoff
