I have been fighting my dual 40 Webers, partially due to learning as I go (carbs have always been a weak spot for me). So when I transferred them from my 1.8 to the 2056, I did not do everything I should have when they were off. I DID change the venturies, main, idle, emulsion, and air to Mr Raby's recommended spec. I did NOT, however, check/adjust the float measurement (Jake had included #'s for this as well) or the needle/seat for wear. So, some of my troubleshooting is actually stuff that should have been done initially. I have taken apart the carbs on two seperate occasions to do things that should have all been done before the carbs were even put on the new motor.
1st time apart, check float measurement....WAY off. Too far in, and too far down. Adjust to correct spec. Also examine needle/seat and find groove on both needle's. REPLACE.
2nd time apart, chasing gremlins out of idle circuit. Take out all 4 idle jets, air mixture screws, and carb tops off. Spray carb cleaner down into top of circuit and let soak, then blow out with air. Replace flat o rings on mixture screws.
BTW, Jakes jetting recommendation for dual 40's on his/Marks 2056 was:
32MM venturi
55 idle (50 actually worked better for me)
130 main (135 w Cali crappy gas - I stayed w 130)
200 air (180 or 190 at sea level - I went with 180)
F 11 emulsion
Float - 10MM in and 23 on the drop.
Thanks to a few of my friends holding my hand and walking me through the storm... and also to Mr McMark for a really solid carb 'lesson' he was kind enough to give me over the phone a few weeks ago ~ I am proud to say...
THE GREMLINS ARE GONE!!!
Hopefully for at least the weekend!
