MrKona
Feb 14 2009, 10:05 PM
I bought a five lug set up today from a local guy off craigslist. The front is a Boge set up with 3" spacing and M-calipers. I already have a pair so I will most likely be selling these off in the near future.
It's the rears that got my attention. The hubs are originally five lug, not four lug redrilled for five. The guy who sold them to me took them off a 914 he parted out a long time ago and has been storing them ever since for an eventual five lug conversion. He sold them as he has too many projects as is.
Unfortunately, I'm going to be gone for a few days and won't get a chance to dig into these until next weekend. I'm wondering if I may have acquired a set up with 914/6 stub axles.
By the way, anyone have a suggestion on how to remove the big castle nut with the suspension off the car?
MrKona
Feb 14 2009, 10:06 PM
Front...
boxstr
Feb 14 2009, 10:33 PM
Let me guess, the guy lives in Columbia City, out by St Helens.
I emailed him last night and asked how much he wanted$$. He replied $300.
I said I will take them. He replied Okay they are yours.
He says he can deliver to OC on way to work. Okay, sounds good.
Then I get an email today that the five lug is gone, for $500.
I guess money talks.
MrKona
Feb 14 2009, 10:41 PM
QUOTE(boxstr @ Feb 14 2009, 08:33 PM)
Yah... I made him an offer today (actually less than $500) and he took it. Sorry Craig... didn't know...
boxstr
Feb 14 2009, 10:50 PM
Yeah, No blame to you. You didn't know.
my928s4
Feb 14 2009, 11:05 PM
QUOTE(MrKona @ Feb 14 2009, 08:05 PM)
A decent impact wrench worked for me.
Todd Enlund
Feb 14 2009, 11:14 PM
Man, I was way too slow...
So, Bryan... your other struts are 3" as well? I've got a pair of "A" calipers/hubs/rotors, and need some 3.5" struts.
MrKona
Feb 14 2009, 11:24 PM
QUOTE(my928s4 @ Feb 14 2009, 09:05 PM)
Yup, I'll use an impact wrench on them, but with no car on the other end of the axle, what do I use to keep the axle from turning? My wife recommended I find a couple of strong men to hold it.
MrKona
Feb 14 2009, 11:26 PM
QUOTE(Todd Enlund @ Feb 14 2009, 09:14 PM)
3.0" struts only here, no 3.5"... I'm sure there is a set of 3.5" struts out there with your name on them...
LarryR
Feb 15 2009, 12:47 AM
My experience was that I was lifting the entire back end of the car off the ground to break those bastards loose. I would take a torch and heat them up a lot then hit them with the impact to bust them loose. a couple days soaking of liquid wrench could help too.
As for being factory six all you have to do is look at the solid rotor to realize that is not the case. However, I am confused as to why they are 5 lug calipers (non vented) but have no extra holes on the rotors. (early 911 rotors working with the 914 hubs?)
great buy.
Todd Enlund
Feb 15 2009, 12:49 AM
QUOTE(MrKona @ Feb 14 2009, 09:26 PM)
I'm sure there is... I'll look harder when I have more money
Looks like you scored big on this setup.
McMark
Feb 15 2009, 01:28 AM
914/6 had solid rotors in the rear. What's the price on those 3" front struts? PM me.
Katmanken
Feb 15 2009, 09:37 AM
Dremel and hammer and chisel, buy a new nut.
Ken
Eric_Shea
Feb 15 2009, 10:22 AM
Couple of things:
Nut = Acetylene cherry red and then have a go at it. You may want to use that one solid rotor we see in the picture and, by first removing the backing plate, put it in a vise. You'll have to crank down on it but, if you can get that nut hot enough it will probably spin. All this depends on the proper air wrench as well. They're not created equal.
What is it? = I'd check the front end first for clues. The spline count will probably be 911 for sure however, check the torsion bar thickness. You may have the 17mm 914-6 bars. That would be a clue.
Rears would be easy enough to tell. Hubs should have a 901 part number on them. CV's would be 914 sized CV's. Real -6 stub axles have a cast finish on them. Search a thread by Reid on the subject (Lavanaut) from last month.
The left rear arm would have an extra tab for the heater flapper cable. This is just a simple tab maybe 1" wide by 1.5" tall with a single small sheet metal screw hole in it that a vinyl/cloth strap was looped through to hold that cable on 6's. Bear in mind, these control arms were used on all early 914's so it's nothing unique however, with 901.xxx.xxx.xx hubs, factory stub axles and this tab, you probably have a set off a six...
...now; where that car he stripped?
sixnotfour
Feb 15 2009, 10:27 AM
The caliper in the background is a -4 caliper.
Whats the spline count on the axles?
The front hub looks to be hubcentric which would be later.
736conver
Feb 15 2009, 11:38 AM
If you cant get em off, you can always ask your local wrench to remove them.
Hey Craig cant get all the deals.
MrKona
Feb 15 2009, 01:47 PM
I had to spend some today to see what I've got... I took Eric's advice with the disk-in-the-vice technique and heat. My impact wrench loosened the axle nut without too much trouble. I was pretty surprised.
I tapped the stub axle and out came.... what I believe is a 914/6 stub axle! 28 splines, sure looks like one, but I've only seen them in pictures! Can anyone confirm?
MrKona
Feb 15 2009, 01:48 PM
Another..
MrKona
Feb 15 2009, 02:15 PM
On the front, I measured the torsion bar diameter at 18.0mm with 29 splines. I believe this matches up to a stock 914/4 (stock diameter 17.9mm) bar.
my928s4
Feb 15 2009, 03:18 PM
QUOTE(MrKona @ Feb 15 2009, 11:47 AM)
Once I got a hold of a decent impact wrench I just held the drive shaft by hand and the nut came off, sounds like you had similar luck.
If you have a 914/6 rear end, sweet find for sure.
rhodyguy
Feb 15 2009, 04:53 PM
nice score.
you should have known better craig. what are ya? NEW!!? i'll be surpised if the other parts will be avail.
k
Eric_Shea
Feb 15 2009, 05:05 PM
Something on those stub axles doesn't look factory. The nubs to be more specific. I could be wrong...
sixnotfour
Feb 15 2009, 05:52 PM
could they be 108 ?
this more interesting than the Dationa 500
zig-n-zag
Feb 15 2009, 06:56 PM
The mittlemotor stubs I sold, seemed to have a thicker flange where it
mates with the cv joint, that was my impression of them.
They also could be 911 pieces added to the trailing arms, if not real /6.
Well bought!
MrKona
Feb 15 2009, 09:07 PM
QUOTE(Eric_Shea @ Feb 15 2009, 03:05 PM)
Perhaps this solves one of the greatest Porsche mysteries ever... what really happened to the special pair of prototype stub axles meant for Ferdinand Porsche's 914-8. 38 years later, it is a mystery no more...
There are no markings on them. I haven't yet taken them off the CVs, won't be able to do that until next weekend. I'm using a picture of 914/6 stubs from Pelican parts (attached) for comparison.
Eric_Shea
Feb 15 2009, 10:41 PM
Here's a picture Andy posted in Reid's thread:
Looks like they could be the real deal.
JRust
Feb 16 2009, 12:34 AM
Excellent! Nice find Bryan
I wonder on the set as I bought & sold a 75 I think years ago. It had a complete 5-lug setup on it. I wonder if you could special order one that way. The car was pretty unimpressive besides. I wouldn't have thought someone made the swap
. I know the car made the rounds as I sold it to Craig who later sold it to someone up in Portland. Guy told me they were real 6 rears on it? Car was a 75 though? One o fthe cars I sold I should have hung onto
Eric_Shea
Feb 16 2009, 09:57 AM
Not that I know of.
Lavanaut
Feb 16 2009, 12:35 PM
28 splines, yep, you're golden! Nice find. Looks like those things have taken some abuse, I wonder if this is cause for concern? "I" wonder, others here will just know.
MrKona
Feb 21 2009, 12:18 AM
QUOTE(Lavanaut @ Feb 16 2009, 10:35 AM)
Click to view attachmentI don't think so... the grooves are equal on both stubs and and look like they're "supposed" to be there. Strange though, as they are absent in the pictures of other 914/6 stubs... I noticed that too...
MrKona
Feb 21 2009, 12:22 AM
I've begun to disassemble the rear trailing arms. I drove out the hubs with a metal pipe and hammer, and then removed the stubs from the CVs. I had to figure out how to hold the axles to loosen the CV bolts with the axles removed from the car. I ended up bolting the already removed hubs to the disks, then clamping the disks in a vice, then fitting the stub inside the hub, which worked just fine.
All I can say is what a dirty, greasy, disgusting mess this is.
MrKona
Feb 21 2009, 12:24 AM
Tonight I removed the bearings from the trailing arms. In order to do this atraumatically, I made a homemade bearing puller for about $10 and a trip to Ace Hardware.
MrKona
Feb 21 2009, 12:26 AM
Bearing cap and removal... Did I mention what a dirty mess this is?
MrKona
Feb 21 2009, 12:27 AM
Bearing cap removed..
MrKona
Feb 21 2009, 12:28 AM
My homemade tool in action!
MrKona
Feb 21 2009, 12:30 AM
And the result! Held the big bolt with a Vice Grip, turned the nut, and the bearing came out like buttah!
MrKona
Feb 21 2009, 12:31 AM
Bearing removed...
MrKona
Feb 21 2009, 12:36 AM
Question... the inside of the trailing arm looks as though it has a plastic sleeve in there... am I seeing this correctly? The reason I ask is that I was planning on bringing both trailing arms to the local metal cleaner and have the grease and grime taken care of before I have them powdercoated. However, if these are dipped, the plastic will melt. Anyone know for sure? There's just too much grease in there still for me to get a good look.
I also need to call my local powdercoater and ask him how dirty a piece he'll accept. I know media blasting can clean parts up, but these are really dirty...
Gint
Feb 21 2009, 08:53 AM
QUOTE(MrKona @ Feb 20 2009, 11:36 PM)
There is no plastic in there. Just grease... and dirt.
kconway
Feb 21 2009, 09:07 AM
Did all of the bearing come out? Isn't there suppose to be a cover over the balls?
Eric_Shea
Feb 21 2009, 11:04 AM
JeffBowlsby
Feb 21 2009, 11:30 AM
Please post the specs of the items needed to fab this bearing puller?
Gud yob mon...
QUOTE(MrKona @ Feb 20 2009, 10:30 PM)
MrKona
Feb 21 2009, 12:29 PM
QUOTE(Eric_Shea @ Feb 21 2009, 09:04 AM)
Yup, thanks guys. This morning I stuck a magnet onto it, you are right, it's all metal. Off to the metal cleaner these go for a bath.
MrKona
Feb 21 2009, 12:36 PM
QUOTE(Jeff Bowlsby @ Feb 21 2009, 09:30 AM)
Gud yob mon...
Thanks Jeff. I used an 8" x 3/4 " bolt and appropriate nut. Of course, different threaded pieces could work. The important parts are: 1) Black piece, which is a "3" fitting cleanout adapter" from the plumbing section of the hardware store. The small end has a 3" ID and just shy of 3.5" OD. The large end (which rest on the trailing arm) has an ID of 3.5" and an OD of 4". 2) 2" diameter washer which mates with the bearing. 3) 3.5" large washer which rests on top of the black plumbing piece.
I added a couple extra washers on top of the large washer as you can see from the pics. This really wasn't necessary. Only needed if the nut is too small for the hole in the large washer.
Also, If I really wanted to get fancy and avoid holding the threads with a Vice grip, I could have added two additional nuts and cinched them tight to one another, then held one with a wrench to avoid gnarling up the threads.
MrKona
Feb 21 2009, 12:39 PM
QUOTE(kconway @ Feb 21 2009, 07:07 AM)
Yup, it's there, it all came out. Hard to see with all the dirt and grease...
JeffBowlsby
Feb 21 2009, 10:21 PM
Thanks Bryan! That saves me some time...
QUOTE(MrKona @ Feb 21 2009, 10:36 AM)
Gud yob mon...
Katmanken
Feb 22 2009, 10:04 AM
Looking at the splines, there are two different approaches used to make them.
The ones in your find are machined using a circular cutter that travels longitudinally along the lenght of the spline area. That type of machining would produce the characteristic "V" at the end of the groove (see red arrow).
How would you do it in 1970's? Hans in the machine shop would attach to a mill and enables him to rotate the axle stub around the shaft axis in an increment of 360 degrees divided by the number of splines. Once the axle is held at the first groove positon positioned, Hans moves the bed into the axle to create a circular slot like a keyway, then Hans makes the bed travel longitudinally to cut the slot.
Then Hans cranks the axle stub away from the cutter, and moves the bed back to the start position. He then rotates the axle by one spline amount and resarts the process. Remember, the whole time he is cranking this thing back and forth by hand to make the splines..... Or, maybe a rotary indexing tooling.
For the production splines, you produce the square end in the groove (see blue arrows). To do this, you might use a rotary approach where a really hard spline tool is made that resembles a gear is both pressed into the axle (unhardened state) and and rotated around the axle shaft to produce the splines. Or, a linear broach could also make the square ends to the grooves.
Prolly a few more processes but the point is, they may be a handmade very low volume part.
Ken
MrKona
Feb 22 2009, 12:23 PM
QUOTE(kwales @ Feb 22 2009, 08:04 AM)
Ken
Ken, Thanks - Very interesting information...
- Bryan
MrKona
Feb 22 2009, 09:25 PM
So what's the secret to removing the rubber bushings from the trailing arms? I heated up the metal around the bushing today, hoping to be able to pull it out in one piece. Yeah, right... Instead, it was bit, bit, by tiny bit of rubber. Is there a trick to it?
Eric_Shea
Feb 22 2009, 10:53 PM
I use a simple press. It would probably pay for itself with this job. It's one of those things you can't go wrong with at HF for $99 bucks.
Step 1: Set the shelf to the proper height. Heat the shaft and press it through the fist bushing. You can see the bushing melt like butter as the hot shaft goes through it (settle down Slits).
Step 2: Take a large screwdriver to the "inside" of the now exposed bushing and pry up. You should have to do this 3x before the bushing pops out.
Step 3: Lower the shelf one notch, heat the shaft again and press it back through to it's original position.
Step 4: Raise the shelf one notch, heat the shaft and press it the remaining way through until it pops out.
Step 5: Repeat step 2.
Hope that helps but... if you don't have a press or don't intend on getting one, maybe take these notes to a friend or shop that has one.
Others will weigh in and tell you to burn them out and stink up your garage.
