Just inspected my oil pump, it is a Type I pump in my 914 Type IV motor. It is an after market cast iron pump 1.15 inch long gears, .004 inch clearance between ppump cover surface and gear tops (without gasket) and a .004 inch gasket for total .008 clearance between gear tops and iron cover (body is also iron)
Pump is stamped on cover "8mm" and "USA"
Is this a good pump, my oil pressure could have been higher.
thanks dave
