$150: Covair turbo chrome air cleaner
$100: Covair turbo muffler and associated exhaust pipes
$100: Crown rising rate fuel pressure regulator (for fuel injection systems only - approx 30-50 PSI)
$100: Ak Miller adjustable waste gate w/ instruction sheet
$100: Wilhelm Bibbero Research intercooler 2" OD
$300: Rajay Turbo - no part number plate - 3 bolt T3 flange for in/out + extra exhaust flange. Probably a VW or small 4-cyl application.
$100: Aluminum 2 barrel carb intake w/ Holley carb, air cleaner housing, and heat shield for Rajay turbo
$60: 4 new Rajay compressor housing gaskets and 3 new Rajay Viton O-ring gaskets
$150: 914 Turbo exhaust header (from head up to Turbo)
$100: Modified 2.0 intake box w/ 45 degree elbow
$100: J&S Electronics boost retard module w/ dash control knobs, box, associated wiring, and instruction manual. This unit controls static timing and degrees of retard per pounds of boost.
If anyone is interested, please contact us at 865-463-2575, 914rrr@comcast.net, or send a PM. We have photos of all the parts available upon request.
Thanks!
