orange914
Feb 21 2009, 03:51 PM
kenny is looking into a used outback to replace his crunched dd. we are looking to spend $5,000 and can find them around the 100,000 mile mark. from what i've seen a well maintained one should see 200,000
in looking into these (2.5) engines, blown head gaskets and oil leaks keep coming up. any experiances with this and/or is this just a poor maintenance issue (headgasket)?
what should we look out for on one of these used cars?
is the 2.2 better (reliability) or other?
mike
pktzygt
Feb 21 2009, 04:04 PM
QUOTE(orange914 @ Feb 21 2009, 04:51 PM)
mike
I am only experienced with the 2.0 ans 2.5 turbo motors, which are a whole different beast. Do some searching on nasioc.com.
carreraguy
Feb 21 2009, 04:07 PM
Hi Mike:
Mine was a turnkey by Renegade so I don't have a wealth of info re: other Subie engine options. As I recall, Renegade highly recommended the 2.0 liter (EJ20) turbo; they said its a lot easier to deal with the harness conversion and other install issues. There are plenty of other Subie converters on this forum that I'm sure have more recommendations.
orange914
Feb 21 2009, 04:39 PM
thanks guys for the responses. i think i need to clairify abit. we are looking to buy the whole vehicle as a dd. i figured i'd pick the brains of you suby conversion guys out here. what is your experiances with any weaknesses related to these drivetrains and what to watch out for in buying a used (2000ish) outback/impreza.
is the (non turbo) 2.2 better mechanically/reliability than 2.5?
is headgasket failure at 80,000 miles a weakness or myth?
carreraguy
Feb 21 2009, 09:39 PM
[/quote]
[/quote]
Mike, if you are asking about which Subaru to buy,
Subaru Owners Club is a friendly bunch.
DBCooper
Feb 21 2009, 10:38 PM
I owned a 97 twin cam 2.5 in a GT wagon. Fabulous grocery getter. You didn't say what year, but the only Subaru engine with a head gasket problem was the 96-99 twin cam 2.5. Subaru came out with a five layer head gasket that solved the problem, so if it's a twin cam that's been fixed then it's not a problem any more. If it's any other engine than the 2.5 liter twin cam it won't be a problem. And if it needs to be done it's not a big deal. It's a little like condemning all Porsche engines because the T4 drops valve seats. I've fixed both, done the work myself, and the Subaru's easier and cheaper to fix than a dropped seat in the T4.
Subaru's are great. The WRX engine in my 914 is a 2.0, different engine. I thrash the hell out of it but I'm pretty sure the rest of the car will give up before that motor. It doesn't complain a bit, just change the oil.
dlo914
Feb 21 2009, 11:28 PM
Great info, my buddy just picked up a clean roller for a suby project. As far as the wiring harness goes does anyone know a good place to get the 914 harness spliced with the subaru harness? And how are you guys fabbing up the engine mounts?
charliew
Feb 22 2009, 02:21 PM
On the motor mounts do the search thing, lots of solutions. On the buying a suby for a dd go to nasioc, not here.
orange914
Feb 22 2009, 03:31 PM
QUOTE(DBCooper @ Feb 21 2009, 08:38 PM)
Subaru's are great.
DB, that's what i was wondering
. i'm speaking from ignorance still... is the 2.5 engine in the 96-2002ish outback (not impreza) the twin cam refered to? wouldn't you think they have all been upgraded by now at 100,000 miles?
mike
charliew
Feb 24 2009, 12:10 AM
Also the dohc suby is a interference motor and if the belt breaks it's pretty expensive to repair.
orange914
Feb 24 2009, 12:43 AM
QUOTE(charliew @ Feb 23 2009, 10:10 PM)
1 are the (98 trhu 02ish legacy and impreza) 2.2 and 2.5 both same family AND dohc engines?
2 are only some interferance motors
3 are all belt (no chain) driven?
dlo914
Feb 24 2009, 01:23 AM
I posted up a thread on NASIOC.com earlier tonight asking about the EJ22, since we found one for a smoking deal and are planning to use it for our 914 suby project. Here's the thread:
http://forums.nasioc.com/forums/showthread.php?t=1706487
74 sunflower 914
Feb 24 2009, 12:18 PM
You might also want to look at a Forester. It is based on the shorter-wheelbase Impreza and so can be set up for more nimble handling than a Legacy. Here is a link about 2003+ Foresters (basically tall sti's). You can sometimes find high mileage examples for $5K or a bit more. I've owned 2 and they are super-reliable, fun to drive (for an SUV) and seem to handle the mild off-road stuff more comfortably than the Grand Cherokee we had.
http://www.subaruforester.org/vbulletin/f7...ti-cheap-10696/
orange914
Feb 24 2009, 07:18 PM
QUOTE(dlo914 @ Feb 23 2009, 11:23 PM)
http://forums.nasioc.com/forums/showthread.php?t=1706487thanks i'll read up
i'm thinking about checking this one out, it's a
salvage title, but... it may fit our needs though... under $5k, lowest miles i've seen on 98-00's, new clutch and nice color/spoiler options (fairly rare), loaded sport package. the 00's seem to range high 5k to mid 7k. i'm thinking to offer 4k out the door if it checks out. what do you think?
http://www.autotrader.com/fyc/vdp.jsp?ct=u...;standard=false
orange914
Feb 26 2009, 09:34 PM
QUOTE(orange914 @ Feb 24 2009, 05:18 PM)
thanks i'll read up
http://www.autotrader.com/fyc/vdp.jsp?ct=u...;standard=falseSOLD... picked it up for $4k out the door. 2.2 5speed outback sport, 96,000 miles, sunroof, both rear spoilers and new clutch. the std. features of air, power windows/locks all work good. it is a salvage title but had quality rear quarter repair. drives down the road solid, straight and quite.
WRX914
Feb 27 2009, 07:17 PM
From what I hear the reason why they blow the headgaskets is it is made out of an organic material. Get the Cometic laminate gasket and the problem is fixed for good.
