QUOTE(slackin' at work @ Feb 24 2009, 10:45 PM)
super beetles don't have steering boxes or rag joints... they have rack and pinion. you need to disconnect the u-joint, or take the whole steering column/wheel out first.
but as stated above, there is no way to raise the body and roll the pan out since the front suspension has struts. you need to pull the body off the pan, leaving the pan where it lies. 2-3 strong guys can move the body it it's stripped down well enough.
I usually make some 6' wide x 3' tall saw horses and place them under the heater channels.
Im sorry, but I need to ask... why are you doing this to a "super" beetle?
I know all about the front suspension deal...
The front will go on a dolly for the short term.
the body will get moved off the pan...I know I cant roll it.
why a super...well, it is my sons car that we re-painted a while back..at that time we replaced the driver side heaterbox...well that thin ass piece of crap is now gone...the original passenger side box is still fine..
I think we got an old part that was sitting for way to long on a shelf in a wet barn...damn shame really.
This time we are removing the body so we can do the pan with new chemicals and just have an easier time dealing with some tight areas around the front tunnel horn...it needs some work , grinder and paint and it will just be a better job if we take it off.
I am not going to replace the heater box as a whole unit.
I have all the parts to make a heater box and I will feel alot better when I can seal up the inside this time...the previous aftermarket part obviously had nothing sealing the inside of the box...we will do better.
Yes, this car sees year round use in salt and snow.
So did all of mine and they lasted alot longer...5 years is not ok.
The vendor who made this should be ashamed..it was made from 22 gauge and it fell apart in 4 years.
The car has sat for a year.
He is back from school, fenders are off, bumpers are off...he has been busy.
He also has strong backed friends...
At the end of the day, the superbeetle suspension is a better design...before you argue, look under all your cars...macpherson struts survived...torsion springs did not survive the engineering evolution.
Rich
