CountryBoy
Feb 23 2009, 07:16 PM
Has anyone had any experience with mounting a 914-4 motor
to a Volkswagen Bus transaxle?
Let me know,
Countryboy!
Wes V
Feb 23 2009, 07:24 PM
What year bus transaxle?
Cap'n Krusty
Feb 23 2009, 08:04 PM
Bolts right up. Gotta replace the flywheel and clutch with a (tranny) year appropriate unit, and put a pilot bearing in the bore in the end of the crankshaft. If it's a reduction gear style trans, there are custom flywheels available.
The Cap'n, BTDT lotsa times
CountryBoy
Feb 24 2009, 07:14 AM
The transaxle is a 76 Type 2 Bus! What year do you think is best?
Countryboy
Cap'n Krusty
Feb 24 2009, 09:38 AM
QUOTE(CountryBoy @ Feb 24 2009, 05:14 AM)
Countryboy
That's perfect. I have some '76-'79 flywheels around here someplace. Cheap. The Cap'n
sean_v8_914
Feb 24 2009, 11:30 AM
2.0 L Jet FI in a 73
Bleyseng
Feb 24 2009, 11:32 AM
76-79 091 bus tranny is nice, 228mm flywheel and you must use the proper year bus starter or it won't engage the teeth right. The 914 2.0l heads run hot in a bus and can crack..the extra hp is nice but watch out for running hot CHT's.
CountryBoy
Feb 24 2009, 04:29 PM
Thanks, Guys!
Keep the info coming!
CB!
Dr Evil
Feb 24 2009, 04:43 PM
Are you attempting to use a bus tranny in a 914, or a 914 motor in a bus?
