nigolusa
Feb 24 2009, 01:38 PM
Does anybody know if this is the correct installation of the passenger side fuel rail?
The photo is looking down from the engine bay.
Cap'n Krusty
Feb 24 2009, 01:50 PM
The hose tap points up, so yours appears to be upside down. The Cap'n
nigolusa
Feb 24 2009, 01:52 PM
This so called Porsche mechanic screwed me along with other things. Should brand new injectors contain remnants of rust?
Also, what attached to that middle hose tap point?
QUOTE(Cap'n Krusty @ Feb 24 2009, 11:50 AM)
Cevan
Feb 24 2009, 02:45 PM
I agree, it's upside down. For an L-Jet car, nothing attaches to that port. I've attached a fuel pressure gauge there to test my pump and fuel regulator.
It's used on D-jet cars on the driver's side to supply fuel to the cold-start valve.
nigolusa
Feb 24 2009, 03:12 PM
Do these look like new fuel injectors? The so called Porsche mechanic said he installed new ones?
nigolusa
Feb 24 2009, 03:14 PM
Cevan
Feb 24 2009, 05:45 PM
What type of fuel injection do you have on your car? Those injectors look like 2.0 injectors, based on the green color. Definitely not L-Jet. '75 1.8's came stock with L-jet.
r_towle
Feb 24 2009, 05:52 PM
QUOTE(Cevan @ Feb 24 2009, 03:45 PM)
I Do Not
Yes, your metal fuel rail is upside down.
Rich
Cevan
Feb 24 2009, 06:38 PM
QUOTE(r_towle @ Feb 24 2009, 06:52 PM)
I Do Not
Rich
From the bird site. It's also how my '74 2.0 came.
ClayPerrine
Feb 24 2009, 10:43 PM
Those are NOT L-jet injectors...
Those are D-Jet injectors.
IF you still have the stock injection, they won't work properly. Different impedance. They will pulse, but the injection pulse will be a lot shorter. D-Jet injectors take more voltage to fire than L-Jet. So you get a lean mixture.
Plus the plugs won't fit in them.
dlo914
Feb 24 2009, 11:10 PM
