Has anyone ever seen a problem where an apparent short in the starter circuit randomly engages the starter while the engine is running? I think this is an issue with my car.
My current 914 had starting issues from the day I got it a year ago. Since I had a Raby engine in the works I wasn't too inspired to troubleshoot the problem. I installed a starter booster relay and it worked fine. Then some time later while out driving there was a horrendous screeching noise. I shut off the engine and pulled over scratching my head. After a couple of minutes I tried starting it again. Afterall, the Raby engine was coming and the worst that could happen was I would have to be towed home. Miraculously the engine started and ran fine. I pulled away and things were fine for a short while. Then it happened again. I let the engine run and jumped out to try and isolate the noise but could not. Then the noise quit. I made it home without any problems determined to find the problem.
The problem became apparent the next time I tried to start the engine. The "clunk" in the trannie told me the starter was ruined. I pulled it off and discovered the starter and flywheel gears were ground off to nothing. Without further troubleshooting I blamed the booster relay since the problem only surfaced after its installation. I pulled the trannie, replaced the flywheel and starter, and drove the car only occasionally while awaiting my new engine, transmission, and just about everything else.
The new engine arrived, went in with all the other new stuff, including starter. There were some issues getting everything together but nothing mechanical. Plus, I replaced the ignition starter switch, just "in case."
Everything was fine until tonight. Shortly after starting the car I heard the screetch again. It wasn't quite as horrendous as with the other engine but I was shocked. Just to be sure I wasn't hearing things I fired it up again and as soon as the engine caught there was the noise.
This time my troubleshooting included disconnecting the yellow starter wire and starting the engine via the screwdriver method. Quiet, no screetching or grinding. This weekend I'll pull the starter and confirm it truly did engage the flywheel while running.
Has anyone ever experienced this problem? Any recommended solutions? I'm thinking of by-passing the solenoid wiring circuit and installing a 911-type starter button.
Just for kicks, here are the old and new engines:
Click to view attachment Click to view attachment
