Just completed my first 100 miles and did an oil and filter change.. I decided to also upgrade the engine harness. In doing so I made a mistake in the coil wiring. I initially had the negative on #3 and the positive on #5.
After realizing the mistake I move the wires down so the negative is on #5 and the positive is on #7.
Did not think that this was a big deal since:
#3 = 0 voltage
#5 = 3 volts
#7 = 12 volts
But now I have not spark in any of the cylinders. I check my grounds and it they are fine also checked the fuses all ok.
Could I have ruined the coil, How can I check it and ideas?
Thank you,
Dan
