Here is the deal; my parents are buying me out of my ownership in my 914. Don’t worry it’ll still be a family keeper. It will be paying toward my newly purchased daily driver… 2000 Subaru impreza … I’m asking for a HONEST estimate on what you think my 914 is worth in today’s market (what you would pay if you seriously wanted to purchase it). I realize prices may be considerably different than a couple years ago, so please read over, and THEN click the survey on your guesstimate. Here we go………
1973 PORSCHE 914
CAR HISTORY
As far as I can find out, I’m the 3rd owner of this 99% rust free 914. The 1st owner was reportedly a car collector in Napa, I purchased from the 2nd owner 4 years ago. It had the original signal orange paint and was accident free. Unfortunately an accident happened. It bent the bumper (which was replaced and rechromed), fender and nose received damage. The original rust free steel was professionally re-worked and fixed, and a complete quality base coat/clear coat (with zinc primer) was applied. The 2 stage paint was to the factory code. Everything we have done, and as far I can tell, all the previous owners have done, has been quality repairs. From what I know, this car was a very well optioned 914. it was originally a 1.7 but its been converted to the 2056 with modified 2.0 Djet injection.----this car was one of the first thousand 1973 models. (slated for Europe but imported to California due to demand) to know more about the car in detail click the links below…
http://www.914world.com/bbs2/index.php?sho...c=67816&hl=
Here is a link to a past 914worldpost (May 2005) of the accident and insurance repair.
http://www.914world.com/bbs2/index.php?sho...c=42614&hl=
Award winning car of the year for local paper, w/ a few outstanding entries at car shows
THE GOOD:
*Recent quality repaint. Fenders rolled for clearance previous to paint, zinc primer (future rust inhibitor)
*Recent falken directional tires (about 200 miles on them) 205x60x15 on western 15x5.5 rims
*Recent brakes (about 300)
*Recent clutch (about 300 miles)
*Interior (unmolested/very clean mostly stock interior w/ original blaupunct am/fm radio,
*Upgraded to duel cht gauge in console
*Koni red shocks all the way around
*Front sway o.e.m. sway bar
*Fuel pump re-located to front/ steal fuel line conversion
*Optima red top BRAND NEW dry cell battery
*00 gauge battery cables
*Headlight bulbs and all exterior bulbs replaced, European lenses front and rear
*Original tool kit bag and a few tools
*Stainless steel exhaust manifolds
edit:* has 2 way paging alarm
THE BAD:
*Engine (d-jet/tune) needs final drivability tweaking
*One rear transmission mount needs replacing (clunking)
*Driver door window has fallen inside (off track?) and driver door doesn’t unlock from key
*Radio is original but does not function
*Non original power antenna loose, could be replaced or new o.e.m. installed
*Oil temp. gauge in console needs to be mounted/completed.
*Speedometer cable needs lubed
*Install wipers/arms on car
*Secure battery
*Straighten up engine hose/component routing
MOTOR
Brand new 2056 complete rebuild
2056 ENGINE SPECIFICATIONS: http://www.aircooledtechnology.com/cylinderheads.htm
71mm stroke x 96mm bore
- Len Huffman prepared .039 2.0 Porsche http://www.haminc.biz/vw/type4.shtml
- relocated and sized spark plug
- valve 42x36 mm
- improved seat material and machining process
- 55 cc combustion chamber volume
- chromoly retainers
- stainless steel valves
- h.d. lightened valve springs
- case
- 2.0 “GA” case
- line bored (0.50mm) .020
- balanced rotating assembly
- all 4 rods/bearings and nuts balanced
- lightened flywheel
- 2.0 crank turned (0.25mm) 0.10 main, (0.25mm) 0.010 rod, std. thrust and micro polished
- 5 dowel pinned flywheel to crank
- oil galleys drilled/tapped
- 96mm 5.675 cc dished pistons, balanced
- Jake raby RAT 9550 cam/cam gear and matched parkerized lifters set
- modified D-jet fuel injection, - M.P.S. recalibrated by bleyseng. - .74@15hg, 1.23 @4hg, 1.41@ W.O.T.
- 1975 2.0 ecm “052”
- pertronix electronic ignition/flame thrower coil
- spark plugs NGK paret # 2598 (NGK DPR8EA-9)
- 1.7 stainless steel exhaust/monza muffler or header & glass pack
- estimated 110-120 H.P.
EXTRAS
Secondary Header and muffler
Porsche center reflector
Genuine real Germany license plate (already installed)
Original 1.7 engine with dropped seat
thanks for you guys time, you probably know more about my car now than me!
kenny
