Full Version: headlight motors
toon1
I need to get them out to paint the front trunk.
Thank's, Keith
jmill
You need to disconnect the bellcrank arm, the nut on the motor shaft and the 3 bolts on the motor housing . I gently smack the motor shaft with a plastic hammer and the motor pops out. You can pull out the relay and pull the rubber relay connection through. Disconnect the harness from the motor and your done.
toon1
Great! thank's, it was the relay portion that was confusing.
