QUOTE(jsayre914 @ Mar 1 2009, 03:33 PM)
am i actually hearing the bearings when i hear this sound?
We can't hear it. Can't tell.
Could be the mains, more likely it's rod knock.
Catch it quick and you might not have to buy a new crank. They're expensive.
If the rods are really bad it can drive the piston right up into the head.
They'll break. They're expensive too.
it has happend about dozen times for less than 2-4 secs each occurance, am i about to blow this engine....
probably...
it is still safe to drive right, it shown no symptoms if i drive like miss daisy.
you will not be injured. The engine is already hurt (sounds like...).
But there's replace-parts hurt, and there's big-money hurt.
...which bearings are we talking about.
I'd guess rods at minimum. It'd be foolish to get far enough into the engine to replace those and have a look at the oil pump and -not- finish the job by having the mains and crank looked at. With luck you may save the crank and case. But if you've lost enough bearing that you have oil pressure issues there is metal running through all the bearings.
