QUOTE(turnaround89 @ Mar 1 2009, 04:08 PM)
So the thin gasket won't be enough, i need the thicker one. Is there anyway to make the intake runner flange thinner, grinding or something to get more threads? If not, how do i get longer studs and how do you get the studs out?
You don't *need* them. It'll run fine with the paper gaskets, provided you can get them to seal right. The flanges better be perfect ...
However, in my experience, the thicker gaskets are beneficial.
Longer studs are plentiful at your local hardware store. Removal is easy with the good old double-nut trick. You might have to get two relatively thin nuts, depending on how much thread is sticking out of the head.
Andy
