QUOTE(retro914 @ Mar 2 2009, 11:11 AM)
I guesstimated it would be cheaper because I can do most of the work myself, if it came to putting a GM motor in the car. If I sent the motor off to get rebuilt, I'm looking at shipping fees and GM parts are DIRT CHEAP. And from my estimates shipping for engines and parts are not cheap. The only reason I thought of a conversion, is based solely on I'm at my wits end trying to locate someone in my area that deals with VWs, and Porsche engines. I don't mind the $$$$....well, almost...but I would like to invest some of my time in the build also.
I gotta ask... if you can do the conversion work yourself, why can't you do the rebuild work yourself?
One way that I saw it when I was making the same decision...
Right now, you have a used engine. You can rebuild it and have a new engine. Or you can do a conversion, and have a different used engine.
Or you can rebuild a different engine and do a conversion.
I'm sticking with a type IV, but I'm building it as a larger displacement. It was going to be a 2258 until I found that my 78mm crankshaft was cracked. Now, it may end up as a 2270 or 2316.
