QUOTE(Dave_Darling @ Mar 4 2009, 07:45 AM)
That's not true. The current for the starter does not loop through the FI wiring. If you look carefully at the diagram, you'll see that a trace runs along the right side of the board from the yellow wire on the top connector to the yellow wire on the right-rear connector.
I think you're misreading the post.
Yes, that's what i pointed out, the starter wire goes from Pin 1 on the forward connector through the relay board to Pin 6 on the backwards connector.
So, if you were to eliminate the relay board, you would have to "jumper" those two wires for the starter to work as expected.
However, he is correct that the same current is also routed to Pin II on the FI connector!
Andy
