This might be a silly question but I thought I would ask if anyone has experience.
On my other car, when I upgraded from the stock ATE brakes to Brembo's all around and used the stock master... I found the pedal to have a spongy feel. Even though there was no air or leaks. I should add, these were vacuum assisted brakes.
Now for my 914 I'm wondering if I were to go to the biggest master I can get (say a 23mm) if the pedal might feel like a rock then and the brakes really sensitive. I'm planning to run 944 S2 rear Brembo's as my fronts and then I have a set of what I've been told are from a 964, but they are a smaller two piston Brembo's.
Anyone on the forum had any experience running larger brakes and loosing pedal feel on their 914's?
