13b914
Mar 11 2009, 07:00 AM
Does anyone have any detailed pictures of the zerk fitting install for the front and rear bushings. I tried the search function and came up with a few pictures but nothing real detailed. I would also like to know if the bushings are suppose to move around the rear trailing arm axle or is it suppose to be tight around the shaft. thanks in advance
charliew
Mar 11 2009, 01:07 PM
Check out the pictures of the ones done by the professionals. Racer Chris, etc.
Joe Ricard
Mar 11 2009, 07:34 PM
Not much to it. drill a hole where it will be accessable tap it and put in the grease fitting. Obviously before putting the pivot shaft in.
Pay attention to the depth of the fitting make sure it doesn't protrude too far.
RoadGlue
Mar 11 2009, 09:00 PM
QUOTE(13b914 @ Mar 11 2009, 05:00 AM)
Oooh oooh, I do, I do!
http://pixelrandy.zenfolio.com/p183342115It's easy!
13b914
Mar 12 2009, 04:12 AM
QUOTE(RoadGlue @ Mar 11 2009, 07:00 PM)
Thank you very much, that is what I needed to see
Chad
913B
Mar 25 2011, 05:03 PM
Any chance I can see the pics ?
jmill
Mar 25 2011, 05:30 PM
Link is pwd protected.
Hint: You are a bot.
