QUOTE(Aaron Cox @ Mar 15 2009, 07:02 PM)
The dizzy tells the BOX when to fire the coil right?
Yes, but...
the stock tach is current-sensing. When you remove the original coil, the switching current (points or electric points-replacement gizmo...) is now only a few milliamps. This might not be enough to trigger a tach reliably, especially an older one.
MSD's (and the Crane HI-6) provide a tach-trigger output just for this purpose. Try that first if using the original points trigger connection doesn't work for you.
It's time for my rant on the MSD 'tach adapter.' It's just a friggin' loading coil that presents an inductive load for the points just like the original coil did. My first time down this path was with an early CIS Rabbit that required a reliable tach signal to keep the fuel pump energized. I was shocked at what I saw in the box after parting with my money, especially when i had to do it TWICE because the first one (recommended by the wizard boys at Autotronic) didn't work and "Ooh, I guess you really need the high-current one after all - did we mention electrical parts are not returnable?"
I don't recall the exact loadings but the 'regular' adapter is something like 3-4Ω and the "high-current" is about 2.8Ω
If that sounds like the nominal resistance of an ignition coil - bingo... So if you've still got one in your parts stash, it's worth a try. (tape over Terminal 4...)
It's half-a-transformer, and I've always suspected that you could go to your local big-box hardware store and get a doorbell or thermostat transformer and have it work just fine - but I didn't have to go down that route so it is left as an exercise to the reader...
The 'tach adapter' can't be costing them more than a couple of bucks, copper content notwithstanding, and their "value pricing" designed to capitalize on the desperation of a car guy who needs 'just one more last bit' to get his project running rubs me the wrong way.
Or just buy a Monster tach that can run with the voltage-trigger levels that are compatible with CD ignitions... It'll fit right in the dash...
