[quote name='scotty b' date='Mar 22 2009, 08:16 AM' post='1148258']
SLUGS! Detuned engines, emissions ( thermal reactors ) Engine is a good candidate for a rebuild and upgrade. Cams need to be swapped, head studs as usual, pistons need to be swapped for higher compression ( IMO ). Get rid of the reactors, get a good earlier exhaust on it. typical 911 rust issues. Front suspension pan, check the torsion bar housing for rust as well as the area around the torsion bar covers, front doglegs. 6K isn't bad if it really is in good shape.
[/quote]
[quote name='JRust' date='Mar 22 2009, 08:43 AM' post='1148271']
I was thinking in 77 it would have a 3.0
Is it a 2.7 then?
[/quote]
[quote name='jasons' date='Mar 22 2009, 08:55 AM' post='1148281']
--><div class='quotetop'>QUOTE(scotty b @ Mar 22 2009, 08:16 AM)
</div><div class='quotemain'><!--quotec-->
[/quote]
Wouldn't a 77 be zinc dipped?
[/quote]
Marks arrow points to the serial number I added a red circle for the type number of the engine. It will be in the form of 9XX/XX I am predicting that it is 901/03 or one of the 69 T stampings :
