QUOTE(chivana @ Mar 16 2009, 12:40 PM)
new to this hobby but planning a restoration to my 914 to hone my skills before tackling the 356 A.I would like to build a structually sound rotisserie that would adapt to both cars.Any prints incl. material lists available?Thanks,Kirt
easy as pie, no real blue prints needed.
Get 2 700 pound engine stands from Harbor Freight (usually can be had for ~$39 each)
Take some measurements on your car, you will be mounting to your bumper pick ups.
Make sure all your steel is 1/8 inch thick walled.
get some beefy rollers from Home Depot.
Any sttel yard in your area will have everyhting that you need. You will need mostly 2x2 inch square tube steel. You will need to cut the upright and section in a foot of metal, and I forget what that deminsion is. Just measure it, and order it from your local steel yard.
Your feet at the bottom you want at 4 feet apart.
The spreader at the bottom (between the engine stands) is important.
Should look about like this when you are done:
All told, you will spend about $300 in stock. When you are done you will be able to sell it for $500-$600. Easy.
Measure twice, order cut and weld. Sell it when you are done for a profit.
Oh, Auto Atlanta has free plans on their site.
Zach
