Since I recentedly removed the turbo from my 2.0, I wanted to replace lots of little stuff while I have the engine out and the sheet metal off. Stuff I am looking for includes;
1. gray injector boots
2. black injector boots
3. boot for cold start valve
4. boot for manifold temp sensor
5. heater control cable and boots
6. injector seals
7. drivers side wiper arm in excellent to NOS condition
8. stainless steel alan head screws for engine sheet metal - I have some existing alan screws on the sheet metal that are knurled, are these Euro, aircraft, or ???
9. boot for MPS and distributor points
10. possibly a complete '73 2.0 injector wiring harness
11. boot for trans reverse switch
12. rubber seal for oil pressure switch
13. rubber seal for head temp sensor
14. boot for transmission reverse switch
15. 3 rubber seals for the rear engine sheet metal
16. heater hose seals
17. Viton push rod tube seals
18. gaskets for throttle body and cold start valve
19. intake manifold gaskets
20. injector seals
21. 2.0 muffler gaskets
22. copper head to exhaust pipe gaskets
Any help with sources for these parts would be appreciated...other than AA.
Thanks!
Rob
865-463-2575
