QUOTE(tornik550 @ Mar 17 2009, 08:31 PM)
...I did not think that I did anything that should affect the headlights. Please help!
my _guess_ is that you have a ground floating.
When the engine (alternator...) is off your headlights are finding a ground through some weird path. When the alternator is supplying charging current, it is energizing whatever component was allowing current to flow through it previously.
Are your headlights working really well, or is it just a vague glow?
Highbeams and low beams both affected the same ?
You may have to resort to tracing through the wiring diagram, but first, find and clean the headlight ground points really well (from the 'it couldn't hurt' file...)
