jimtab
Mar 20 2009, 12:07 AM
Mark fixed the sagging right rear by fixing the "alignment" I had done at a shop here in town who convinced me he knew what he was doing....so I fucked up. Now where do I take it? When HPH had it done for me, it came back and I got uneven tire wear....tried the new guy....not so much McMark said he had to re-index the adjuster TWICE to get the RF down(it was so high it was pushing the rear Left down.....Damn, no wonder the car was handling funny....so I need to know who to take it to, as close as I can get to Pacifica....thanks.
Dr Evil
Mar 20 2009, 01:01 AM
Just lose some weight
roadster fan
Mar 20 2009, 01:25 AM
Hey Jim,
This is the place I have heard the bay area guys swear by. I have not been there so it is only word of mouth, hopefully others will chime in.
Custom Alignment in Mountain ViewHope this helps,
Jim
ConeDodger
Mar 20 2009, 08:00 AM
Jim,
Doesn't Jerry Woods do that in addition to engine work?
Dr. Roger
Mar 20 2009, 12:37 PM
He is in Pinole but John Holleran does them. But uses an outside companies rack.
He's in the process of building a 914 street/racer right now.
At least it would be done right.
r_towle
Mar 20 2009, 05:41 PM
Do it yourself.
Its simple once you do it one time...you will kick yourself for not doing it yourself alot earlier.
PM me if you want instructions.
Rich
underthetire
Mar 20 2009, 05:45 PM
I would like the directions!
MartyYeoman
Mar 20 2009, 06:27 PM
Jim,
I use Brandon Kraus at Roger Kraus Racing in Castro Valley.
He knows what he's doing. A real 914 guy.
The number is 510-582-5031
Marty
jesiv
Mar 20 2009, 08:10 PM
QUOTE(underthetire @ Mar 20 2009, 04:45 PM)
I have the same issue (yes losing weight would help). I would like directions also!
Regards,
James
Dave_Darling
Mar 21 2009, 09:26 AM
I've used Custom Alignment for my 914. Good work, not cheap. Good communication, good results. Corner-weighting is especially not cheap, particularly when they wind up needing to swap parts around to get the weights to work out.
--DD
jimtab
Apr 16 2009, 02:51 PM
I want to thank everyone for their input on this, I finally made a decision and the winner is Custom Alignment, they are the closest one to me and they answered all my questions like I wanted. I just bought 4 new 195/65R 15 Bridgestone Potenza RE960AS Pole Position tires, so back to "standard" ride height and a bit narrower tire from my 60 series 205s, but I'm just tired of scraping on everything all the time.....also a little better gas mileage and the speedometer will humm at a lower rate.....maybe.....
