QUOTE(knuckledrgr914 @ Mar 25 2009, 10:15 PM)
Thanks MDG and McMark! Looks like it is a 1.7, but I will make sure to measure the cylinder bore to see exactly what it is. Unfortunetly the individual I purchased the '70 from had the carburators off and water got in the jugs. I tore it down today and found quite a bit of rust, but luckily it did not get down in the motor (crank, cam, ...). I am sure I will be spending plenty of time in the garage forum while rebuilding the motor and getting it back on the road.
Brad
Brad, the fact it has carbs is your first indication that at least
some mods have taken place; might be just a swap from the original FI - but it might also indicate what Mark mentioned earlier. Again, once you get into it, the garage is the place to go for any advice you may need.
mike
