QUOTE(MBowman325 @ Mar 23 2009, 10:37 AM)
I'm not local, I'm sure someone will pipe up.
But -- what is is not doing? No crank, crank won't start.
Is it still FI (L-Jet / D-Jet) or carb(s)?
Did it used to work?
It was sort of working but the fuel pump was bad.
Installed a new fuel pump, and gas tank with new gaskets, lines, etc.
Everything is wired correctly. Touched fuel pump wire to positive and can hear the fuel pump working.
When the key is on, and I push the flap on the AFM, the fuel pump does not activate?
Also, when turning the key to start there is a delay, then the starter turns, but the engine doesn’t fire. The starter just turns over and over.
I checked the dual relay, also checked that power is coming to the socket. All seems to be ok.
Since I’m a newbie just learning this stuff, I’m at a total loss at this stage.
