orange914
Mar 23 2009, 06:32 PM
does any one know where to get a set of tail light lens gaskets/seals?? you know the sealing strip inset on each lens. what do you use?
jonferns
Mar 23 2009, 06:34 PM
The white gasket strip? AA sells them.
ahdoman
Mar 23 2009, 07:37 PM
I found that they were too thick and my tail lights stuck out. I eliminated them and used a very small bead of silicone.
6freak
Mar 23 2009, 07:43 PM
QUOTE(ahdoman @ Mar 23 2009, 05:37 PM)
they will smush over time and give a better fit a strait slot driver will help get them deep in the slot ...............silicon !have fun changing your next bulb
76-914
Mar 23 2009, 10:27 PM
I think the Dr. @ Automobile Atlanta has them?????
mojorisen914
Mar 23 2009, 10:48 PM
Yes, the Doc has them. I got a set from him not too long ago. Use a wide screw driver and they'll work fine.
I agree with 6Freak; good luck changing your next burnt out bulb.
Wilhelm
Mar 24 2009, 12:50 AM
What about 3M Butyl tape? Shouldn't have the acid problems of silicoln.
dr914@autoatlanta.com
Mar 24 2009, 07:02 AM
yes on the shelf. We duplicated the original ones which were more pillowed that old shrunken ones. These new ones will shrink also so put them in with a screwdriver and install and let the shrinking begin!
Grelber
Mar 24 2009, 08:14 AM
Got mine from AA and put them in last week. It went quick and easy with a broad screwdriver.
rfuerst911sc
Mar 24 2009, 04:16 PM
QUOTE(mojorisen914 @ Mar 23 2009, 08:48 PM)
You guys shouldn't assume he applied the silicone to the lens and then installed it to the housing. I'm guessing he applied the silicone to the lens, let it dry overnight and then installed. That would be fine and removable.
6freak
Apr 1 2009, 02:56 PM
QUOTE(Wilhelm @ Mar 23 2009, 11:50 PM)
That butyl tape(LIKE TAR) is a nightmare to remove if so desired and it makes for hard lense removel as well..But i do think its ok around the lense buckets its about the only thing thats available anymore for the buckets..right?? if there something better let me know
FourBlades
Apr 1 2009, 07:31 PM
I know this sounds crazy, but a thin bead of cheese whiz around the perimeter
will seal it up nicely. Get the real Kraft stuff, not the cheapo off brand. You
can enjoy whatever is left after the repair with a nice box of wine.
BIGKAT_83
Apr 1 2009, 07:38 PM
QUOTE(FourBlades @ Apr 1 2009, 09:31 PM)
Works only if smoothed out with a chop stix.
Dave_Darling
Apr 1 2009, 10:38 PM
Check out the stuff they use to hold screens in. It's a thin rubber bead, and at least one size it comes in is close to the same size as the stock gasket.
--DD
jaxdream
Apr 2 2009, 07:28 AM
QUOTE(6freak @ Apr 1 2009, 12:56 PM)
I too am looking for something to seal the bucket portion of the rear signals , someone suggested that they RTV'ED thier buckets , but personally I prefer the silicone to be inplants , just feels better !!!
Jaxdream
6freak
Apr 2 2009, 09:13 AM
QUOTE(FourBlades @ Apr 1 2009, 06:31 PM)
Dont forget the Ritz Crackers
...spend more time work`n on your car you have a ways to go
orange914
Apr 4 2009, 04:31 PM
in the produce isle next to the door jam
FourBlades
Apr 4 2009, 04:46 PM
Check the date on my post...
But I do agree about the Ritz crackers though.
Door jam...
orange914
Apr 4 2009, 08:49 PM
QUOTE(FourBlades @ Apr 4 2009, 03:46 PM)
Door jam...
just ribbin' ya'... quite creative though
mike
6freak
Apr 6 2009, 10:21 AM
Door jam...
aH.. F@*# YA GOT ME
