Click to view attachmentQUOTE(kyracedog @ Mar 24 2009, 05:33 PM)
Looking for specs for front and rear alignment for a V8 powered 914 for DE use.
Will be running 7 x 15 front wheels, 8 x 15 rears, with Hankook R tires, 205/50 and 225/50/
Front has 84 Carrera front struts and brakes, new torsion bar bushings, stock torsion bars.
Rear has 200 lb springs...
Hi kyracedog:
I've been running and developing my 914V8 for over 5 years now and finally feel I am getting the "handle" on the handling for the car. I run at Willow Springs in SOCAL.
I'm running a 500 HP 383, 930 trans with Quaife, 9.5" wheels front, 11" rear on Hoosier DOT slicks. For stability on-track, I also have poly-graphite bushing in all the suspension arms. So there are a bunch of differences in our cars, BUT there are some things about the design and from my experience I have learned:
First off, with your 200lb springs in the rear, you r spring rate is QUITE SOFT and yoiu will get GREAT traction meaning you will have WAY TOO MUCH understeer. I've been fighting understeer in my car for 4 of the last 5 years and FINALLY got the rear to start to work with 450 lb springs (however, I also have 22mm front torsions bars and a swaybar). BTW: The ride is still fine at 300-350lb springs.
Second: This has been a BIG surprise for me: we MUST keep the car at nearly stock settings....those Porsche guys designed it to run at the standard ride height and lowering the car SCREWS up all the suspension camber arcs.
3rd: CAMBER: I AGREE with starting out at 2.5 degrees of NEGATIVE on all 4 corners when running radial tires. BTW: be sure to pump pressures up in the 34-38 lb range for track running and check the wear. On my car I started out at -3.0 degrees and it seemed right at first. However, as I went stiffer & stiffer, I needed less and am not at -2.0 degrees.
SORRY, but I DISAGREE COMPLETELY with ALL the settings offered by sww914 and will explain why.
4th: Front toe is to your taste. 1/16" is all that you need for a stable car. I tried running TOE-OUT in the front as it is said to help "turn-in response", but it makes the car very nervous and you MUST drive it all the time....no relaxing. Currently, I'm running 0 front-toe and it's fine. If you have rubber in your front suspension, a SMALL amount of toe-in would be a good way to go.
5th: the Rear Suspension: I took bump-steer reading of the rear suspension and was AMAZED what I learned: The Loaded wheel in a corner TOES-IN .200" in 2" of upward travel from ride height!!! At the same time, Unloaded wheel is moving DOWN and TOES-OUT .200" in 2" of travel. I hope you can visualize it: when in a corner, BOTH wheels deflect and point INTO THE CENTER OF THE CORNER. This makes SURE there is no oversteer (remember Ralph Nader & the Corvair). What we end up with is UNDERSTEER!! Thus, I would recommend running NO rear toe-in on our car to start and if the understeer is still BAD, you could go toe-out. I would think 1/8" toe-out would NOT make the car unstable and might get the tail to move a little. A few weeks ago, I was at the Monterey Historics and was talking with a Porsche race shop specialist who was preparing a 914-6 for a fat old guy who couldn't drive. When I brought up what I found about the rear suspension, he just nodded "Yup, I set all 914s at 0 rear toe or toe-out." My car is set a 0 toe now, but after my next track day, if I can't get the right balance with my new rear swaybar, I'm going TOE-OUT!!!
I hope what I have learned THE HARD WAY will allow you a short-cut to a better balanced car!
Best,
Terry
