QUOTE(type47 @ Mar 25 2009, 05:56 AM)
What makes it specific to a '72 model? I have one but I thought all 1.7's were the same. How about $25 + shipping from 22180?
"'72 is a one year only application, with a heat riser for warm up. If you get rid of the heat riser in the firewall tin (by the starter), you can use a '70-'71 air cleaner and then all you need is the 'stand" and the bolt, as well as the intake air boot, of course. If you use the plastic air cleaner housing from a '73, you'll be unable to find the correct air filter, although there are smaller (and more restrictive) filter elements that will fit. The Cap'n"
do you also have the stand, bolt and boot as mentioned above?
