Ok, Thanks.
Well, Cap'n, I don't know that it is worn out, but all the components on the engine were checked/replaced during the rebuild (except the oil pump) and no doubt I could have an issue else where. When the engine gets good and hot, I see about 6psi/1k rpm which is certainly lower than I am happy with.
Now, I have heard it said "There are two types of 914 owners, Ones with low oil pressure problems and those without an oil pressure gage" but I'd like to keep 10psi/1k rpm for my sanity.
As I only get sporadic times to work on my 914 (as it is in upstate NY at the parents while I am down in NJ havin' babies) I thought I should just assume it is bad and if I go through the effort of pulling the pump, I might as well have one with me to replace it should I find it bad.
I am planning on adding an external oil cooler at this time, as well and thought that more volume flow might be a good thing for the additional plumbing.
Ok, SO, let me recap and answer questions;
1. Thanks Jake, If I replace it (without splitting the case), I am constrained by stock or melling pump, . I've heard that people avoid the melling due to the difference in body material and modulous of expansion. Do you have any reason not to suggest I buy one?
2. The interferance fit is sometimes not as bad as I've read.
3. To do it right, I should split the case, clearance the gear and install a T1 larger gear pump.
4. Conventional wisdom says that stock T4 pumps don't wear out much, so the problem might be else where.
5. DBGriffith, The Engine is a 75 1.8l (with 96mm KB pistons) in a 914 case that never had the secondary oil pressure regulator. I might take you up on buying a good stock pump from you.
Once again, this forum is a lot of fun and a great resource. I hope to repay to others what help I've gained here.
Thanks
