weird_looking_cactus
Feb 26 2004, 12:44 AM
Brad Roberts
Feb 26 2004, 12:47 AM
Go back and shrink your pics down to something like 850 x XXX.
It looks like you have a decent car.. now to get it running.
The interior is COOL.
B
Feb 26 2004, 12:50 AM
Im not sure how to shrink them down. But I hope to get this thing started by tomarrow once I rewire the starter.
Brad Roberts
Feb 26 2004, 12:53 AM
Umm dont rewire the starter. Figure out what is wrong with the stock system.
You can create one large pic with your photo editor, but you cant shrink them ??
www.irfanview.com free photo editing software.
B
jonwatts
Feb 26 2004, 12:54 AM
It's winter in Utah. Stick your camera outside, I'm sure something will shrink.
McMark
Feb 26 2004, 01:09 AM
It's not one large pic. It's a bunch that just line up like they're one big pic.
rick 918-S
That infran is great free ware and easy to figure out. I like the plaid! If it's not ripped just have the vinyl repaired on the side of the seats. Like Brad said, Don't reinvent the wheel. Get a wire diagram and figure out where the short for the starter is and reapir it.
Anyone know of an online site that has the wiring scematics for cactus?
Feb 26 2004, 01:19 AM
Haha I was just thinking of getting rid of the seats cause I just want all black ones the plaid color is now a dirt plaid color. A wire diagram would be nice if someone can find one or make one.
campbellcj
Feb 26 2004, 02:10 AM
I "think" the Bird Board site has wiring diagrams. Also they are in the Haynes manual.
I dig the plaid seats too...unfortunately I believe you that the fabric is toast after all that time sitting outside. A black vinyl recover should be pretty straightforward.
I also see you have a center console and speaker boxes are intact, etc. Looks like some good potential...keep us posted.
Cheers,
campbellcj
Feb 26 2004, 02:12 AM
OK...I don't see a 75 but I highly doubt the starter circuit would be much different from the earlier years...
http://www.pelicanparts.com/914/914_electr...al_diagrams.htmIf you're bold and energetic, you could always try to push start it
Bleyseng
Feb 26 2004, 08:26 AM
The starter wire is a solid yellow thick wire that goes from the starter to the relay board then onto the ign switch. The other wire on the starter is the huge red wire to the positive side of the battery.
Pull the harness connectors off the relay board to see if they are all corroded or burnt. Clean them up, and use a ohm meter to test them for continuity(breaks/shorts).
Bet the problem is in the ign switch.
Geoff
davep
Feb 26 2004, 08:37 AM
Okay, are we missing things here? This car should have the seat belt interlock and all that jazz. Are you following proper procedure? Seat belt done up and sitting in the seat. Is the interlock relay in place? Do you need to replace the ignition switch? All major causes and cheap fixes. You'll kick yourself for replacing a starter that was still good.
DaveP
Bleyseng
Feb 26 2004, 08:40 AM
Some other stuff, you should be able to clean the seats up or take them to a detail shop for cleaning. They are way cool.
Clean out the rust in the Hellhole.
What is that thing in the middle? Part of the air pump stuff?
Love the old cellphone too.
Geoff
Feb 26 2004, 10:38 AM
I know the starter was bad cause I brought it to auto zone and they tested I even watched the test. It started to spin but very slow like you could stop it with your figures and made some weird noises. Then he stuck the new started it and it was super fast and would be impossible to stop. The car phone still works to all I need is service but I have no clue were I get that at. What did you mean by the seatbelt interlock. Also were is the ingintion switch located.
type47
Feb 26 2004, 10:47 AM
seat belt interlock is the stuff under the passenger seat. it prevented the starting of the car unless the seat belt was buckled (if there was an occupant of the seat) most people have deactivated the system. lots of discussion/explanation of the process here and on the bird (pelicanparts) board
