QUOTE(Cevan @ Mar 27 2009, 10:42 AM)
One of my 2.0 injectors is stuck closed and I've sent it back to the place that cleaned and tested it to get it unstuck. In the meantime, can I use a 1.7 injector in it's place just to sort the motor out (dwell, timing, shifter rod adjustment, etc)? It looks like the flow rates for the 1.7 and 2.0 are 265 and 380 cc/min. Both far exceed the L-jet injector flow rate of 190 (data from Jeff Bowlsby recent post). And I've read that L-Jet works pretty good on a 2.0 motor.
It would work, but I wouldn't do just one. Might lean out that cyl. You could do 4 and increase fuel pressure by a few psi.
