QUOTE(Cap'n Krusty @ Mar 28 2009, 10:50 AM)
A 36 HP bottom end with hundred horsepower heads in a car 1.5 times the weight the engine was designed for. Makes sense to me. Oh, I almost forgot. Generally about $8-10K to overhaul, if there's nothing really broken. The Cap'n
I am totally in agreement with the Cap'n on this one... The 616 doesn't even have cam bearings!
You'll be going absolutely backward in every regard if this is done... Thats the reason why the Type 4 conversion into the 912 is so popular these days! Its cheaper to build, more powerful and lasts just as long. The TIV makes an enormous amount of torque compared to a 616, in fact you'll have to modify a 616 greatly (1720 kit at minimum) to even equal the stock torque output of a 2.0 TIV engine in bone stock form.
I build 356/912 engines and won't touch a stock one for less than 10K... The damn main bearings are almost 500 bucks per set!
Bild the engine you have the proper way and spend whats required and you'll be way ahead.
