QUOTE(evangojason @ Mar 28 2009, 01:04 PM)
hey, great site you guys got here. A few quick ?'s. I got a 75 914 awhile back, ran when i bought it home but oil cooler was leakin so i pulled the motor (1.8 carb) and started tering it down. Now unsure weather it will go back in or if I will go with the subi swap. But anyways to the ?'s. First the car was origanaly green and had a bad THICK yellow paint put over it that is flaking off. To do a fairly good paint job should i take it down to bare metal? Not going to be a show car just want it to look nice. Next the hood and the bracing under it has maybe 1/4 to 3/8ths separation between it causing the hood to flex very easy. I seen people squirt foam in between. Is that the correct way to do it?
It would be best to take it to bare metal. Try to find a good used hood,I doubt you will ever get yours to fit right if the skin has seperated from the inner bracing.
Jerry
