First - Thank you!
I would have stopped working on this car long ago if it wasn't for the folks here. 914World has been my oracle for my fun/damn car. And thanks to those that repeat the same thing over and over again in different threads. It is very helpful, when searching and when trying to understand the problem.
Second - the early ball joint / strut bolt:
I suspect my car has hit several curbs or the like. While there is little body damage, I have found a cracked/deformed A-arm, a ball joint that was pulled out of the strut, the other ball joint pin was bent. And both bolts mounting the ball joints to the struts were bent or broken.
The bolts were SAE 8.8 - threaded all the way up the shank.
I thought - This can't be right - silly PO!
German enginering would have used a hardened bolt (SAE 10), with a solid (no threads) shank - threads on the last .5 inch.
But, when I got my replacement hardware - it was ... SAE 8.8 - full thread bolt.
Is this correct???
The old "good" bolt (the other was broken in half):
Ball joint pulled out of strut:
A small alignment/safety problem?
