A few questions, on a 76 2.0 (in CT) if the cat converter has been removed does the airpump serve any purpose and will there be any damage if its removed. I assume you must leave the backflow valve in place to prevent exhaust leaks into the engine compartment. Is it advised to backdate the exhaust and heat exchangers to pre 75 models?
Thanks for your thoughts.
