QUOTE(corvette6698512 @ Mar 29 2009, 12:52 PM)
Probably a simple question, but how does the horn button on the wheel work? Its like there is nowhere for the wire to go to. The horn works, but i cant figure out how to make the switch work. Thanks.
Just adding to last post by HCRDAN.
Don't know if mine is still stock (got an old RaceMark wheel & adapter) but I believe it is. There should be a metal disc with a smaller insulating cardboard disc riveted in the center, and securing a male or female spade connector that the wire connects to. Also a lg. conical spring. When the horn is pressed it presses on the disc, forcing the spring to compress until it grounds the disc to the column and 'beep beep'.
(horn button>metal disc w/ gnd wire> spring.)If it don't beep, wire may be disconnected in the column connector or has broken somewhere.
hope that helps
