QUOTE(slackin' at work @ Mar 29 2009, 07:33 PM)
QUOTE(So.Cal.914 @ Mar 29 2009, 10:08 PM)
No, but it would make it easier.
hmm, really?
do you need to undo the strut and let the arm hang lower?
I kind of gave up when I couldn't get enough play between the trailing arm and
the trans to get the stub out.
anyone have a more in depth plan of attack on this? I really don't want to pull the
HEs if I don't have to.
If I read that right you want to remove the axle still atached to the stub axle?
I seperate the axle from the stub axle and remove it first. I do not unbolt the trailing arm from the shock.
I unbolt the CV from the flange on the trans and the stub axle, tap with a rubber mallot and pull away from the trans
on the inboard side.. The outers can be stubborn, when this happens I use a piece of pipe with a notch cut
out long ways so it slips over the axle. This way I can use it as a 'Slide hammer' to pop the CV loose from the stub axle.
