QUOTE(wertygrog @ Mar 31 2009, 06:47 PM)
That's very impressive! Are you going to make a quick write-up of how you did it?
This version uses the standard distributor with the mechanical advance for timing.
The trick is to replace the rotor with a 4 window rotor and optical devices to let you know which coil pack to operate, with build in safeguard so the coils pack don't
burn up when the engine is not runing. The next version will be a multi-spark just
like MSD does with the 6A unit, now that I know how to do it.
